What is minimum cylinder wall thickness?
Posted: Mon Mar 26, 2012 11:25 am
by Anders F. R.
I still have this idea in my head, to bore out a Model G 350 engine to closer to 400 cc. If I can find a suitable piston, of course, and a cylinder that will need reboring anyway. If I go from 70 mm bore to 74 mm, volume will ingrease from 346 cc to 385 cc. That might provide some more low rev torque.
However, with a 74 mm bore, the minimum cylinder wall thickness will be only 3 mm. Is that safe?
And then there are those questions about the bottom end, will it take the (hopefully) increased torque etc. etc.?
Regards, Anders F. R.
Posted: Mon Mar 26, 2012 6:51 pm
by Geoffers
Hi Anders. Our host, Mr Hitchcock, sells a replacement long-stroke crank which raises the capacity to 400cc with the standard bore. It's meant to give much-improved bottom end power which is just what you're looking for.
T'aint cheap though...
Cheers,
Geoffers.
Posted: Mon Mar 26, 2012 9:31 pm
by Anders F. R.
I think I have seen that long stroke crankshaft before, but I can't find it now. Have seen a 350 to 400 kit, at least.
Anyway: This is for the350 Bullet, isn't it? I have an older Model G, not a Bullet. Don't think it will fit.
Correct me if I'm wrong! I have a spare engine, and if I could have a long stroke crank in that one, without doing too much irreversible end potential damaging things to it, that could be interesting.
400 cc from a 70 mm bore. That will need about 104 mm stroke..... Really a long stroke engine!
Posted: Tue Mar 27, 2012 8:57 am
by Geoffers
My apologies Anders - it is indeed for the Indian 350 only (page 43 of the current catalogue). Sorry mate.
Cheers,
Geoffers.
Posted: Tue Mar 27, 2012 8:42 pm
by Dennis C
Hi Anders
I have a BSA B31 350cc which I fitted a Triumph T140 piston to this brings the B31 to about 410cc and higher compression, the difference was barely noticeable which was quite a surprise, luckily I had a set of Gold Star Clubmans cams in the garage so I fitted these as well, now that really made the difference so much so that I changed the engine sprocket from 17t to 21t.
What was a 75mph bike is now a 95mph bike which will cruise effortlessly at 70mph.
But to be honest I think a 3mm cylinder wall may be pushing it a bit close, but I dont think the bottom end will be any problem
