efi engine dissaster
Posted: Thu May 02, 2013 8:55 pm
by grunda 12
my mate with the efi has had a major dissaster mr crank,s crank has done the big end is totally shot at 15000 miles and has had regular sevicing so it seems simular to the leanburn engine what says you? atb paul.
Posted: Thu May 02, 2013 9:16 pm
by Noel (ogri)
The crankmobile dead nooooo so whats the budget looking like to fix it .
Posted: Thu May 02, 2013 10:36 pm
by Chris Tindal
Even tugging a sidecar it should last longer than that, think your jinxed Juan. Now what?
Posted: Fri May 03, 2013 4:56 am
Now there is a project for you Paul, Hinkley Bonnie in an Enfield, That will certainly pull a chair. Google John Dawes's Trifield. Not sure if it would fit in the UCE frame though because the engine space is smaller than the earlier Bullet frames.Certainly getting back to the old days with Triumph and Enfield pushing out plenty of bikes maybe somebody will start bringing out a conversion kit or a special frame so you can just swap it over from your existing Bullet, bit like the rigid rear end kit
Posted: Fri May 03, 2013 7:03 am
by juan
Went to Barnsley with an engine came back with some peddles fitted I now got legs like Braddley Wiggins! oh the joys of being an Enfield owner ! Lol ! Or you can cry ! One or tuther !!!!!
Posted: Fri May 03, 2013 12:23 pm
by grunda 12
hi noel its up to around £300 at the moment no crank parts bought yet ,also not split cases as am waiting for a few special tools to land ,hi norm i wanted to fit a nice diesel engine in but juan is not convinced as the performance would be like a bsa m20 but is that a bad thing i,m not too sure ,i just cannot believe that these things only last 15000 miles i know tugging a chair increases work load but i actually think its poor anyway i,ve got the job of carrying out the repairs so i best get on with it, be seeing ya!
Posted: Fri May 03, 2013 4:59 pm
by Michael
Hi Paul... Just wondering what the symptoms are which lets you know the crank and big end are shot? My EFI is getting rather noisy and at around 17000 miles has done a lot of heavy miles. And... given your obvious enthusiasm (!) for repairing these beasts... where are you based? Just in case
Posted: Fri May 03, 2013 7:42 pm
by grunda 12
hi michael,the symptoms of the big end failure was a distinct knocking when the bike was coming down on the revs ,i,m based in south yorkshire atb paul ,p.s i have split the casings tonight and the big end is completely shot with distinct wear in the small end bush ,although the rest of the motor looks good
Posted: Sat May 04, 2013 4:06 pm
by Ninetytwo
I'm sure you'll get Juan up and running soon Paul, no doubt he'll come up with one of amusing tales about it, I can lend him a push bike till he's back on the road
Posted: Sat May 04, 2013 4:47 pm
by juan
Thanks 92 but in the meantime Paul has fitted peddles to the empty frame anyway!
