Electra X starting
Posted: Wed May 01, 2013 11:48 am
by sa(lincs)
Hi everybody,can anyone tell me why I have to crank my bike over 3 or 4 times on the kickstart before it will start on the button ? you can crank it all day on the button but it wont have it ( good battery )but turn it over 3 or 4 times on kickstart and it will start on button straight away
Electra X starting
Posted: Wed May 01, 2013 1:38 pm
by Frank
Difficult one. The spark will be at it's weakest when the battery is under load from the starter motor, which is why it often fires when the button is released and full power is available to the spark. Perhaps there is also a lack of fuel getting through and the act of kicking it over a few times primes the cylinder with enough to get it to fire under the load of the starter. Does this happen when it's hot, cold or both?
Electra X starting
Posted: Wed May 01, 2013 4:35 pm
by sa(lincs)
Hi Frank
this happens when cold,so why deosnt the first few revs on starter prime engine?
Electra X starting
Posted: Wed May 01, 2013 9:05 pm
by grunda 12
sa just junk the whole lecky start arangement and kick the bike up ,my electra x did the sprag gears so i removed the lot even the ugly hump on the primary case just hacksawed it off it looks great plus no problems atb paul.
