By Matt - Wed Feb 08, 2012 10:21 am
#20
The clutch operating rod is not able to push on the inside of the cluth front plate.
Obviously the rod's not shrunk so the mechanism is to long..?
The gear box end cover has gone on fine with the main shaft locating in the end cover bearings with no problems so the problem must be clutch side?
With all the clutch plates out the clutch sprocket has some movement forwards and backwards a few mm and when I put her in gear and move the rear wheel there's a grinding sound comeing from behind the clutch center and back plate assembly.
I'm at a loss. The clutch center seems to be mounted on the drive shaft OK and the clutch assembles fine with all plates fitting in the basket.
I've come so far and would love to be able to finish this job myselft. All help is very much appreciated.
