By dennis t c
#24286
Thank you all for your advice, an air leak it was. I looked at the rubber between the carb and the cylinder and its ok, then looked at the PAV tube from the carb to the PAV and found it to be perished at the PAV end, it was loose and pulled of easily. It's now sorted so thank you all once again
