Monoblock fast idle
Posted: Mon Mar 18, 2013 5:31 pm
by Bonnevillesmith
I have a BSA B31 fitted with a 376/29 1" Monoblock. What ever I do I cannot turn the idle speed down. The slide is at the bottom and is a good fit/not worn. I have also checked for air leaks at the manifold and there are none. Any ideas?
Monoblock fast idle
Posted: Tue Mar 19, 2013 11:42 pm
by DUFFEL
Hi Bonnevillesmith You could try a slide with a smaller cutter way Is the inch bore carb correct for that model I would have thought an 1.1/16 bore ??
Monoblock fast idle
Posted: Wed Mar 20, 2013 6:41 am
by Beezabryan
Monoblock fast idle
Posted: Thu Mar 28, 2013 12:32 pm
by Bonnevillesmith
Thanks everybody, may give a new slide a go, if not new Concentric
