- Tue Mar 12, 2013 1:59 pm
#1912
Seems the non standard project 93 bullet I recently bought has a bit of history. It’s used to belong to a Royal Enfield club chairman and then Jim Allen of Lincs fame who used it to holiday 2 up in Holland and Germany. He added and egli dizzzy, close ratio gears, disk brake front forks and wheel and an alloy barrel and forged piston. It had panniers and a fairing back then and I think its done around 25k miles? After that it was made into a clubman style bike in Lincoln area adding twin clocks but removing the fairing. At some point after that it appears to have had a sidecar fitted but I've no info on this but possibly when it moved to the Hull area?
It’s now missing a few parts but has a single trials seat and bars and red mudguards. I have just found and added an ignition side toolbox and plan to add the other side toolbox once I get the correct brake switch to fit inside it.
Harvey
Harvey
