- Sun Mar 10, 2013 6:58 pm
#1906
Hi
My new adjustable cam spindles does unfortunately not fit the case og my 500. The inlet one does almost fit, it can be put in and taken out again by hand, almost without resistance. The EX one is worse. The diameter of the case hole is to big an the spindle tap does not fit at all. The old ones came out ok after heating the case and everything seemed to be good. I don't know why there is difference in the diameter og the taps.
Any idea what to do? Will I have to ream out the holes and put in a bushing? Or will it be ok to use JB Welding or is the load to big to be handeled this way? Anyone with experience of this problem?
