- Wed Mar 06, 2013 9:56 pm
#22965
Hi Simon, I tried this on an Ensign a few months back and it seems to work, I used a 6 volt battery on the external coil to give it good spark to start, works brilliantly but it won't rev using the battery supply, have to flick it back to the magneto and all is good. This Flea I have set up with 12 volt LED's for ease of LED's and a better range of batteries to fit in the tool box out of sight. What I would like to try on this one is the same principle and use a tiny 12 volt coil from a Monkey bike fitted in under the tank but I'm not sure if I could use the existing magneto coil in the same way and combine the outputs so that I could switch from coil to magneto to get it to rev. Somehow in the magneto it is allowing the spark to advance and the only way I see it can is by the 2 pick up points each end of the magneto coil. Any thoughts?
