By Dean
#1859
do I really need the clutch holding tool (ST25104) to replace the clutch? I have the puller (ST25099)
#22857
Hello DEAN --------- you'll need to restrain the clutch inner assembly when you torque-up the main centre nut... You can make your own locking plate by joining an old driver and driven plate together (Bolt, braze, weld---)making sure they are cenralised..
By BobF
#22897
To amplify the advice from Beezabryan and John R, put the gearbox in top and the rear brake hard on. That should be more than enough to stop the clutch mainshaft turning.
#22901
Indian method, shove a rag into the chain infront of the clutch basket on the bottom to undo the clutch nut and to tighten the nut they shove the rag into the top of the basket under the chain.
