- Wed Feb 27, 2013 8:43 am
#22595
Zippy, you need to be more specific than pre-55! The heads changed from push over stub to push in sometime in 1954-5, probably fairly early but I don't have the parts book to hand at the moment. As to plugs, I had a conversation with a plug expert at The Spark Plug Company when sorting plugs for my magneto Interceptor and he recommended Iridium ones. If you're lucky you might find a grade that suits the Bullet that is not a Resistor type (it probably won't be an NGK, mine are NDs,) but he said that the benefit of running an Iridium in an old design oily engine like ours will still outweigh the small disadvantage of losing a little spark through the resistor. You can follow the rebuild of my Ebay bargain (!) 1955 350 Bullet in the Royal Enfield Magazine, free to view at greenlane.biz HTH, REgards, Mark
