BEARINGS DRY OR LUBRICATED
Posted: Sat Feb 23, 2013 1:40 am
by DUFFEL
Im about to put new crankcase roller and ball bearing in my twin if these come out a tigtht fit or I dont need to use a loctite should I put the new ones in dry meaning dry in the housing and dry round the outer casings of the bearing or should they be lubricated with a light oil such as 3in1 / WD to stop fretting and help with locating /centralizing ?
Posted: Sat Feb 23, 2013 3:03 am
by simon
If the twin is anything like the single you will need to heat the crank case halves in either an oven or with a heat gun to knock the old bearings out and then chill the new bearings and reheat the crank case to get the new ones in. No oiling will be required but the cases should be too hot to touch and the bearings cold out of the fridge and they should drop in reasonably easily.
Posted: Sat Feb 23, 2013 6:30 am
Heat crankcases in oven, build temp up slowly til at max (250deg, usually,) then tap bearing races out, if hot enough they may well fall out. The cases will be too hot to touch, the heat will not affect them if you heat gradually! New bearings should be in freezer overnight and once cases are back up to temp will drop in easy. It sounds as if you are new to this so go careful and ask for help if in doubt. Do you have a manual? If not get one. REgards, Mark
Posted: Sat Feb 23, 2013 11:15 am
by MadMike
Dry. The heating and freezing advice above is spot on. You should only require bearing lock if the outer race is loose in the cases already.
Posted: Sat Feb 23, 2013 11:10 pm
by John M
Don't forget to cover your smoke alarm, put baking foil on the oven trays and try and complete the job before the wife gets home.
Posted: Sun Feb 24, 2013 12:33 am
------------- a side order of Coke with some chips helps as well !!!
Posted: Mon Feb 25, 2013 1:57 am
by DUFFEL
THANKS TO YOU ALL YOU FOR YOUR REPLIES AND ADVISE lOOKS LIKE I HAVE TO GO ALONG WITH THE MAJORITY HA HA
Posted: Mon Feb 25, 2013 12:45 pm
Hey guys--------- you lot sound just like the Hairy Bikers giving out one of their recipes !!---- "and here's some bearings we fitted earlier"--LoL ----
