- Mon Feb 18, 2013 7:29 pm
#1822
has anyone got any thoughts regarding the efi clutch push pad /bearing set up on the efi the bearing sits in a steel housing that locates in the clutch centre the push pad runs through the bearing ,on the one i,ve just seen ,the bearing just works as a sloppy support, as the push pad must move ,its got to be the worst piece of engineering i,ve seen in a long time any thoughts?atb paul.
