- Mon Feb 18, 2013 11:51 am
#1821
I've recently replaced the rear brake plate on my 1960 Super Meteor from the steel version to the early interceptor alloy type. There is a difference in design whereby the brake lever cam is fixed in position (because it's been cast) rather than the steel version which is mounted on 2 bolts so that it can slide slightly, (and therefore compensate and centralise itself).
This isn't possible with the alloy version & on applying the brake I can feel the brake lining touching then not as the drum rotates, the drum has been skimmed recently when the drum sprocket was re-toothed, but I think that is co-incidental and it's the design differences of the cam being fixed or moving that is the problem.
Any thoughts? Especially those Interceptor experts who have the alloy brake plate version.
