#1696
Since Rackers bought up the topic of his brakes it's got me thinking about something I have experienced recently, I thought I'll put it out there and see what you think guys. Basically it happened on the rear drum of my Bullet last year and it happend a few days ago on my Montesa. What it is, all of a sudden It felt like there was instant "wear" on the brake causing it to be a whole inch out in adjustment!? I had to move the brake arm back round a few splines to get it back to 90degrees and pulling the brake on again... Nothing appeared to have slipped and no damage. When it happend on the Bullet last year I thought I was just going mad but it happend to me again the other day like I say. Re-adjusted and everything works again 100% any thoughts or am I going mad?
#21573
Yeah, it feels exactly like I would imagine if the rod were to stretch but that's not the case obviously. The other day with the Montesa it happened whilst I was ridding. Last year with the Bullet it was an overnight occurrence.
#21585
Good points. The wheel moving forward is the best possibility I think, but with the snail cams it's unlikely. I will check wheel alignment tomorrow... Could be on to something. As for bending, damaging/ breaking that's not happened. Last year it was on my 500 Bullet which is my road bike and treated with dignity (haha.) On my Montesa the brake arm and rod are above the bottom of the rear spring arm, very much out of harms way (the rod on the Montesa is actually a car clutch cable with a soldered nipple.) It's been on there years and didn't show any signs of stretching.
#21586
Un Scientific But, My 350 happens to act the same * I Put it Down To The Brake shoe's sticking Part O Or Off",..Strip & Grease the rear Brake & New Springs??..But its Winter Again so I Will Put Up With it?.....
"Thought For Today: I have Changed My brake shoes some six times..But Replaced the shoe Springs? Never"..Perhaps that's the Fault.......Lastly I Can Roll My 350 std forward with One finger..Back wards though the Brakes Bind???..."Ride & Enjoy"...Cheers all CRAIG
#21592
This is a bit of armchair thinking and I'm not sure if it's physically possible but here goes... Could it be that you've applied the brake so hard that the activating cam inside the drum has turned full circle? Just a thought??? Cheers. Tony.
#21606
In this cold wet weather armchair thinking is productive planning...Thats what i tell herself.
Hi Riggers. for the cam to turn 180 degrees and leave the arm still pointing downwards still attached to the brake rod would entail completely stripping the splines i think..
Is it possible for a brake shoe to crack near the cam actuator?
Is the shoe cast alloy or cast iron?? Haven't got any to look at as i cleared the workshop. gwilly
