By Enfield Phil
#163
Hi there, just been for a 15 mile ride on my Enfield Electra EFI, got back home and into the garage and the bike is covered in covered in all at the bike end, on closer inspection after a clean up oil is coming from behind the engine casing where the kick start is. I went for another ride in case it had been wet sumping but its just the same. Ive lost a considerable amount of oil as its only just visible on the sight glass, any ideas please or has anyone else had the same problem, Thanks,  Phil
By Enfield Phil
#10493
Just to add that when the bike has cooled down and is on the stand nothing seeems to be dripping only when the engine is warm
#10496
 Hi Phil,
     Don't get concerned about wet sumping, it is a wet sump motor, unlike previous Bullets. Is it leaking from a gasket join or from the kickstart oil seal. It is always hard to pick some oil leaks because the oil gets blown around so much
By Enfield Phil
#10504
Hi Norm, thanks for the info, Ive had a bit of trouble with the kick start of recent, from cold you can never start it with the kick even when its hot its a one off whether it'll fire up using the kick. About 3 weeks ago I was trying to start it this way and there was a loud metallic crack.  Phil
By Beezabryan
#10524
Loud metallic crack?
That sounds like a clue to me.
Something has broken & needs to be looked at
By Enfield Phil
#10525
Hi Beezabryan, thats what I thought, Ive got my local Enfield dealer coming to pick it up next week, good job its still under warranty
#10539
 Phil,
    I know nothing about these UCE's but I will go out on a limb and take a stab at a cracked outer cover. Let's know how you get on
