- Wed Mar 14, 2012 2:49 pm
#160
Hi all
Had just completed some routine servicing on my 2006 500 Classic, then next morning switched it on. Ammeter flickered a bit, then returned to centre. No further movement when I pushed the kickstarter. I checked the kill switch etc. - nothing. Since the ignition switch has long been dodgy I came to the "obvious" conclusion and ordered a new one from our hosts, which I fitted. No difference.
I checked the fuse, lights, horn etc. - all in working order, but still no movement from the ammeter, and couldn't start the bike at all. So obviously the ignition circuit has gone somewhere. My problem is, I am little or no good at testing with multimeters etc. I have read Pete Snidal's manual, and have a few ideas of what to test in what order. However, I would appreciate a bit of help from the assembled experts.
First, Mr. S's manual, when going through ignition testing, makes no mention of the condensor and how it is wired into the points system. The wiring diagram is no help as it doesn't even mention it! Would an O/C condensor cause ignition failure? I did look at the points as part of the servicing but literally all I did was check the gap (it was fine).
Secondly, I'm not sure if a duff spark plug would cause a total lack of function on the low tension side of the circuit - I will put another one in to check, but aside from re-gapping the old one (to the correct value) I did nothing to it that could cause it to fail as far as I can see - it was working perfectly until I pulled it.
Can anyone please give me some idea of how I can test logically for malfunctions, including the condensor? Would be v grateful...
Cheers
TimG
Hi all
Cheers
TimG
