- Mon Mar 12, 2012 8:18 pm
#155
After a second test run from cold, without warm up, the cutting problem is better but not entirely cured. When I close the throttle, to change down, it almost stops, if I give it a blip, it backfires. 3rd run with a 2 minute warm up, behaves perfectly, so maybe the book is dead right.
On the plus side she runs beutifully, cruises at 80 km/h with ease (still running in at just under 1,000km.) Touched the magic ton for a few seconds, in normal riding position. Gets just as many wows as the "old one"
Satified and looking forward to the 18 tooth sprocket next month. Exhaust thump is still there with the standard puffer.
Best regards all
Best regards all
