- Tue Dec 18, 2012 8:26 pm
#1587
Hi. Just brought a 2nd hand Bullet and have the following problem. Bike starts OK but after a few minutes if I rev it up or blip the throttle it only slowly returns to tickover. Gradually gets worse until revs won't die down at all. Fitted a new throttle cable but still the same. Suspected the Slide so brought a brand new Mikcarb VM28 (They are so cheap it is not worth fiddling about with them) and fitted it with the new cable but still the same. I have tried running with the Tank off incase the cable was getting trapped or bent.
Has anyone experienced this problem and found like me that the obvious reasons are not the cause, but found a different reason for the problem.
Cheers.
Mick.
Cheers.
Mick.
