By Phil Ashbrook
#1517
I'm running in a maxed out 535cc , when you use all the parts recomended the engine is not the rattle box it once was , #1 how long should I run in the whole valve train on thin bed in oil , supermarket stuff , big end is older and floating bush with a 2 though run out on the crank , got a filter magnet , 100 miles before the good oil me thinks plus new filter , the 00 semi fluid grease takes a while to bed in layshaft bearings , the 00 grease is so needed on the first gear pinion , she will pit fast in the sprint city I live in , bigger crank breather advantages are there any ?
