- Sat Mar 10, 2012 10:53 am
#138
Hi Guys
I’ve just had the exhaust valve guide replaced on my
1996 500Classic and the engineers enthusiastically silica bead blasted all
surfaces – even the oil-tight ones (barrel-to-head, rocker box bases, rocker box
covers). Grrrrrrrr, I’ll have to lap them
again.
But having been cleaned I can now clearly photograph the
ports and would like to know if anyone can comment on their shapes? Two images are posted in my photobucket
account (ChrisD) of inlet and exhaust, namely: [IMG]http://i940.photobucket.com/albums/ad24 ... ar2012.jpg[/IMG]
and [IMG]http://i940.photobucket.com/albums/ad24 ... ar2012.jpg[/IMG].
In each case the images are annotated with dimensions
for both ports at the outside, at the valve seats, and at the narrowest
point.
The exhaust is large throughout, so I doubt I need
much more work there.
The inlet and exhaust at the valve seats and the
exhaust outlet are all 38x38mm.
The inlet at the carb is 31x32mm as standard Indian,
so my new 32mm Mk2 Amal should fit nicely.
But the inlet port reduces to 24mm high by 30mm wide at its narrowest. Maybe this is why I can comfortably do 95kph
on less than half throttle but only ~110kph at full throttle. I think the inlet port is too “tight” for
good air flow for an engine with ~8.5:1 compression, twin plugs, high lift
cams, oversize (Hitchcocks) inlet and exhaust valves.
So, should I open up the inlet tract to at least
30mmx30mm at its smallest? If so, how
much meat should I leave around the cylinder head studs and the rocker boxes? I guess first prize would be from someone who
has measured up the Hitchcocks tuned 500 head!
Yes, I could buy a tuned head from our hosts, and if
that is what I need to get 100kph (65mph) cruising with a top speed suitable to
get past large trucks at up to 80mph (130kph) then that’s what I’ll do. But cost of the head, plus the postage (adding
~35%) plus tax (adding ~14%) plus customs (adding another ~15%) would make that
a prohibitively expensive test.
Your thoughts and comments most appreciated, as
always.
ChrisD (from yet another boring sunny day in this African
paradise, Cape Town).
Hi Guys
again.
point.
always.
