- Fri Nov 09, 2012 8:26 pm
#1422
Over time, and probably enthusiastic tightening, I've managed to strip threads on the carb body. It's the ones for securing the float bowl to the body of the carb. I'm going to try tap them out a bit bigger but decided as I need wheels I'd get a new carb body. My old body is scoring the slider so I'll replace it for the moment and hopefully use the current one, re-tapped, as a spare.
Right my question: I'll start by saying that I have to take some sandpaper to the float bowl to flatten the surface of it tomorrow, it seems slightly warped at present. That's not the problem that has my head scratching though.
Basically I have the float bowl assembled, (but not on the carb body), and connected to petrol. As you'd expect the bowl fills with petrol and cuts the supply of fuel. I now have a bowl full of petrol. All very good so far. Now I carefully drop the carb body onto the float bowl and hold it secure. Press the tickler and the petrol overflows the carb. Now here's the problem when I release the tickler the petrol keeps flowing??? Remove the carb body from the float bowl. Petrol stops flowing.
I can's see any issue with the new carb body that I'm fitting the only thing in there that can effect the float is the tickler and it's recessed below the lip of the body. I confuses me that when I put the two parts together fuel remains cut off until I hold the tickler and then it won't cut off with release. Float must be getting jammed but there's not a lot in there to complicate things.
Any ideas more then welcome.
