- Mon Oct 29, 2012 6:19 pm
#18947
There's a bit more to it than that but there is a tech note on this site (on menu on the left hand side of the page) explaining how to do the oil seals. It's worth cahnging the oil for something lighter - I use ATF which is about ASA 5. The tricky bit is getting those bottom domed nut tight again when you've finished as the folk stud often wants to spin with the nut. If this happens, get some tension on the spring by using a helper or a ratchet strap or something then the nut will do up. I find it easier to do this once the wheel is back in. You don't need the special tool to guide the stantion back past the oilseals - a bit of cut-up plastic milk carton works a treat. If you are replacing the oil seals you DO need to support the alloy slider, either with the special tool or home made arrangement of jubilee clips. It's all too easy to crack the alloy otherwise.
Classic C5 Euro 4 at the moment.
Also CBf250.
