Electrical Conundrum
Posted: Sat Aug 06, 2022 9:55 am
Hello Everyone,
I'm new to the forum so I don't know whether I'll get banned as I have an issue with a Triumph 5TA!
Let's see.
I have recently acquired a 1958 Triumph 5TA Speed Twin. It's 6 Volt positive earth and has a coil and distributor and uses points but I think it may have had a Boyer Bransden electronic ignition system fitted at some time in the past and subsequently been removed.
The electrics were a bit of a mess so i tidied up some of the connections and removed indicators that had been retro fitted. Whilst at it I removed what looks like a honda 6 volt twin condenser which was connected directly to the coil and bolted to the frame as I couldn't see why it was fitted. I thought possibly something to do with the indicators or the previously fitted electronic ignition but I'm sure it wouldn't have been fitted originally.
And of course it wouldn't start.
I re-fitted the condenser and it runs fine again.
Does anyone know why it's fitted? All I can think is maybe the condenser in the distributor is faulty (it's still fitted) and this has been fitted remotely for whatever reason. I'm clueless with electrics. Would this make sense?
The other thing I've noticed is that when the ignition switch is turned to emergency, the ammeter discharges. The bike fires up on this setting but I'm sure from memory it shouldn't show a discharge. When the bike runs it shows positive charge.
Can anyone, as Joseph Lucas used to say, shed any light on this?
Thanks
John
Let's see.
Thanks
John
