Wheaters wrote:
Mon Jun 13, 2022 4:57 pm
TCI ignition needs a minimum of 7 volts to work properly. I’d suggest fitting a sealed 12 volt battery; you only need a small capacity one seeing that you won’t be using the starter motor. Something like this would do the job: https://www.ebay.co.uk/itm/113201588702 ... media=COPY
Or even go lithium. Those things are tiny and very light. A LTX5L-BS is 113 x 69 x 85mm and weighs 400g. It's only 1.2Ah but if it's only running the ignition, it doesn't need anything bigger. I have a 2Ah AGM battery on my 612 bullet which fits comfortably in the toolbox and it's fine with that because I have LED lighting throughout.
