- Mon May 16, 2022 1:42 am
#100979
Hello,
I have a question about my 376 Amal carb. currently residing in my 1955 Velocette MAC 350.
I have two carbs both 376/48. The newer carb was bought new from Amal and ran fine until the pilot jet became gummed up and I had to drill it out and re-tap (2BA) to accept a new jet. Unfortunately, it never idled properly afterwards as the drilled hole was off centre and allows unmetered air in. This carb still runs fine off idle (1/4-full throttle).
In an attempt to fix this I bought a used body and transferred over everything including jet block and slide. This carb idles nicely but will not run. It's very lumpy and will not rev cleanly.
I bought one of Amal's recon kits in desperation, but that made no difference - good idle but poor running performance.
Reinstalling the original carb and everything was back as before - poor idle and good running performance.
What's going on? Any ideas?
