350 1957 Redditch Bullet Oil/petrol leaking into primary chain case when wet sumps/ Alternator?
Posted: Fri Apr 29, 2022 1:55 pm
As with many old bikes my bullet wet sumps if left unused for a while. Doing some work on the alternator which seems to be failing but after 60 years forgivable but there is an excess of oil (with some petrol mixed in) in the primary chain case. Question one is what seals the primary chain case fro(if anything) m the engine (my Bonneville engine oil circulates into the primary case) since as stated oil here seems to be mixed with some petrol and most importantly how easy is it to change any such seal. Given I understand some people use auto transmission fluid I assume the Bullet is a sealed system. I thus assume there is a seal behind the alternator on the end of the crank shaft but the alternator stator and rotor are not yet removed. I've lived with it for 15 years without knowing so might leave well alone unless an easy fix but suspect not. Second question is if the alternator needs changing can anyone advise which one I need to buy as I have the hexagon stator which is the original 6v but the bike has been uprated to 12v. My parts book says it is a Lucas RM14. It has however worked OK for the 12v system change. I think the hexagon stator has the securing holes in unusual places so its not just any easy swop to a more modern equivalent. Any help/advice appreciated. Hugh
