- Sun Oct 07, 2012 3:42 pm
#1275
Hi all, I need a bit of advice from you experts. 2006 Bullet 350.
I've just taken the cylinder head and barrel off to investigate some piston slap, oil use, reduced performance, high fuel consumption, etc. Turned out this was due to a gudgeon pin circlip having come off and grooved the barrel and piston.
While I was there I checked the big end play. There is no up and down play, but side to side play is 2-3mm, measured at the top of the conrod. The manuals say "some" play is acceptable, but not how much. Is this amount of play acceptable?
Thanks
Ed
Thanks
Ed
