- Mon Mar 14, 2022 10:56 am
#100367
I keep seeing threads about the Himi losing charge, and am still experiencing it myself on two separate Himis and 4 batteries, all replaced under warranty.
The bike has been parked over winter and shock, it's dead again. My 1200 honda which has been parked up right next to it over a year started first time.
The current battery is(was) a known good one from Motobatt. I think the dealerships and Enfield just like fobbing the issue onto the battery as an easy fix which gets them outside the warranty period.
I've done a bit of research online, and there seems to be a few different components people have identified as a root cause.
Sources. https://www.advrider.com/f/threads/roya ... 0/page-102
and Youtube https://www.youtube.com/watch?v=IKbBRqtcw9s
1. Regulator/Rectifier diode leakage. Easy to diagnose
Unplug all but the 3 Phase and do a Diode/Continuity check in each direction on the DC to Battery connection. Should have a value in one direction and 0 in the other. More than zero = leak.
2. Starter Relay Diode leak.
Same test as 1, but across starter motor relay when disconnected from battery but connected to motor.
3. Bad cell in battery.
Next time you don't intend to use it for a bit, disconnect battery the and measure voltage, measure it again just before you use it. If it's losing voltage while disconnected there is a fault in the battery. Note: If you have a parasitic drain, it will ruin batteries over time, so finding a bad battery does not prove you don't have a drain somewhere else.
4. Leaky Capacitor across the alternator. There is a capacitor in the alternator to smooth the AC out but This should be a non issue if the regulator doesn't leak.
5. Wet battery
Battery compartment isn't water tight, if it gets damp enough in there you will get battery drain.
5. Wet battery
