Best place for the electronic ignition module?
Posted: Tue Feb 15, 2022 6:54 pm
by Justin
Hi all
I'm fitting electronic ignition to my 2008 Enfield Bullet. Where do you all feel the best location for the module is?
Cheers,
Justin
Re: Best place for the electronic ignition module?
Posted: Tue Feb 15, 2022 8:48 pm
by Lone Wolf
Wotcha.
I've mounted my electrical gubbins on a bracket under the seat.
The Zener diode is only there as a backup if the reg/rec unit fails.
Posted: Tue Feb 15, 2022 8:56 pm
by Justin
Ah, splendid, good idea. Cheers.
Posted: Tue Feb 15, 2022 9:47 pm
by Wheaters
Some “points are the only way” diehards might say the best place is in the bin! :lol:
Posted: Tue Feb 15, 2022 11:11 pm
by Bullet Whisperer
Yes, me for one!
Posted: Tue Feb 15, 2022 11:16 pm
by Justin
So points should be retained?
Posted: Tue Feb 15, 2022 11:22 pm
Personal preference. There are advantages and disadvantages for both types. ;)
Posted: Wed Feb 16, 2022 12:06 am
by Justin
I used to own a 2CV and fitted electronic ignition, that's why I thought the Enfield one might be good.
Posted: Wed Feb 16, 2022 7:55 am
by Bullet Whisperer
If it is running well, I for one would certainly keep the points and if it wasn't running well I would fix the problem and still keep the points, but other opinions are available!
Posted: Wed Feb 16, 2022 12:17 pm
by Wheaters
If it’s of any use, the TCI module on my 350 Bullet Electra sits under the seat. Although it has waterproof connectors, the factory put it as far out of the wet as it can be.
