oil grades and gear change problems on my low mileage 2006 350cc bullet
Posted: Sun Jan 23, 2022 1:22 pm
Having trouble changing down gearbox ( which slots into false neutrals when going top to third / third to second . I have just purchased the 2007 registered 350 cc Bullet (genuine 4,800 miles) = there is no problems going up the gears or selecting gears from neutral just changing down approaching bends!
Clutch is adjusted properly no slip and 3mm clutch lever slack.
Any tips would be greatly appreciated as would information on THE CORRECT grades of oils gearbox/engine/forks as looking through the "workshop manual" confuses the issue as printed page states use sae grade oils and spec pages say a straight 20/50 with Hitchcock's stating that they use a semi synthetic 20/50. Don't know how long oil has been in bike so want to do oil change hoping that this will help.
Also any one know if Haynes ever did a workshop manual - I find the Indian one lacks a lot of strip down information.
Matt
Matt
