By Andy C
#99712
Has anyone had any problems with theirs?
Mine sometimes refuses to make contact, if you thump the housing with your fist it will work.
I have taken it apart a couple of times and it consists of a fixed contact on one end of a wire and a spring loaded one that makes contact when you press the button.
It looks to me that it is the way in which the spring contact makes contact with it's wire may be the problem - seems to a ring terminal that is rivited to the spring, and I think that it may not always be making a good contact, I am going to take it apart again and see if I cn do anything in this area.
Just wondering if ayone else has experirnced the same .
