By phil bersted
#120
hi guys, hope you could help me on my main fuse, brought my 91bullet 500 in sept 2011  i thought it had a 10amp fuse on it, but they have blown checked the hosts online parts they give a 20amp which i have fitted been ok i would like to no what you guys are running on many thanks ps,first time on message board cheers
#10094
Hello Phil and welcome to the forum-----Only last night I was fitting a mini-blade fuse-holder to my 2005 Bullet 500. The listed rating ( and fitted in mine ) is  }----20amp. So you're ok with yours I would think. I believe an electric-start version may have a higher rating----not sure on that. ope that helps ??
By neddy
#10095
Phil, if its still the glass type do what Alan and many more do and fit a blade fuse/holder, far more common to buy and stands vibrations better.
By phil bersted
#10096
thanks neddy.put my mind at rest did not want to burn the electrics out, will take alans advice and fit the mine blades seems what you guys run on by for now cheers
By 1950s Bulleteer
#10102
Hi Phil, just curious if you are from Bersted, or if that is your name? If yiou are from the village of that name I am a near neighbour.
By phil bersted
#10108
 high dan, your correct. i am at bersted i have just jioned the forum i gave it a thought if you was from ford we must only be a couple of miles away cheers
By 1950s Bulleteer
#10129
Aha I will keep my eyes open for you, is yours a silver grey Bullet, I have seen one parked up in Durban road a couple of times. Mine's a Black 500 with a rather fruity exhaust note ;-)
By phil bersted
#10139
hi,dan not my bike in durban, but i did purchase  it of adrenerlin bikes down there, mine is black with a goldie on it a bit taty but i am getting there,need a new seat cover see our hosts do one might try that, perhaps we could meet for a chat,mobile07779185414 cheers
By triton
#10156
Ok its not related to your original post Phil, but this Sun is the Classic bike Show and Autojumble at Ardingly Show Ground.
The local Brit Bike club have a stand there. Ride out leaves Climping Sports Club at 0830, no rain forcast. Maybe see you there.
Roy of Middleton
