- Fri Feb 11, 2022 12:22 am
#100064
Update No. 2....
I've stripped the entire box down to the last cog! Everything seems fine, only the big bearing is a little gritty.
I would just buy the bearing overhaul kit from Hitchcocks, but I want to be sure that the bearings are the same, mine clearly isn't "indian made". From the kit I can see that the gasket is wrong, I only have 1 o-ring (on the kickstart, not two like in the photo), I don't have the tabbed washer(?)...
Anyone know what the bearings are in the Indian boxes?
My small one is a Hoffmann "115 V2" open with the mark "WVU" on it.
The big one is a SKEFKO "401524" open with the mark "WRSL" on it.
I've not been able to find much about either. My main concern is should they be C3 clearence?
Also, where do you stand on the "open" "sealed" (2RS) shieled (2Z) options?
cheers!
cheers!
