Page 1 of 4
Himalayan Front Mudguard
Posted: Fri Nov 26, 2021 5:47 pm
by Jon Hill
The Himalayan front mudguard is far too short at the front. Road spray is directed upwards, as a consequence and splatters the top of the forks, front of the tank and headlamp. Has anyone a good fix? I have contacted Pyramid to see if they would consider making an extension. I already have a rear extender and a hugger for the rear wheel,which are excellent products.
Re: Himalayan Front Mudguard
Posted: Mon Nov 29, 2021 3:21 pm
by Andy C
John - that annoys the hell out of me !!
Like you I have fitted both a Hugger and front mudguard lower extension, both of which do an excellent job, as you say need to do something at the top of the front mudguard.
If Pyramid decide to do something please let me know, in the meantime pondering a "home made" solution....
Posted: Sat Dec 04, 2021 1:29 pm
by Jon Hill
Result! Pyramid have my front mudguard and are making a prototype front extension. It should be with me next week. I will update ASAP.
Posted: Sat Dec 04, 2021 2:24 pm
by Jon Hill
Result! Pyramid are making me a prototype front mudguard extension. It will be with me next week. aI will report back ASAP.
Posted: Sat Dec 04, 2021 7:02 pm
by Andy C
Great news Jon - please keep us posted.
Posted: Sun Dec 05, 2021 4:58 pm
by Trev
+1 for one of these, I have the rear extension which works well but deffo needs something at the front
Posted: Wed Dec 08, 2021 1:00 pm
by guru
John: why not try knock one up your self m8? In the past i have made some really good mud flaps from a black B&Q bucket (is only a quid as-well), cut the rim off, cut the bottom away so you left with a kind of lamp shade shape, next make a card template then copy it onto the bucket which you will find will cut with stout scissor, a couple of drill holes later, fix in place with either small s/s ny-loc nut bolts or plastic number plate fasteners, job done, once you've made one you make others. Guru
Posted: Fri Dec 10, 2021 6:19 pm
by Jon Hill
The new front extension prototype has arrived. Easy to fit and looks as if it will do the job.
Posted: Fri Dec 10, 2021 6:48 pm
by Jon Hill
Great news, the prototype has arrived. Easy to fit and looks as if it will be effective. Will update when I get out in the future.
Posted: Fri Dec 10, 2021 7:35 pm
by Andy C
Looks good Jon - does it do what it is intended to ?
If so, how do I get one ?
:D
