Himalayan starting issue.
Posted: Mon Nov 22, 2021 8:04 pm
by philipw
Hello.
I tried to start my 2019 Himalayan, however when I pressed the starter button there was nothing. The side stand was up and it was in neutral. After trying the kill switch on the handlebar a couple of times and trying to start it some more, now only some of the dash lights up and the digital display portion doesn't light. The fuel pump does prime. I have ordered a new relay from our hosts and will see what that does. Any comments or advice gladly received.
Thanks, Philip.
Re: Himalayan starting issue.
Posted: Mon Nov 22, 2021 8:47 pm
by papasmurf
Dead battery.
Posted: Tue Nov 23, 2021 12:22 am
by Exile
I think Papasmurf might have it.... It'll be interesting to see..
Posted: Tue Nov 23, 2021 5:37 pm
by Andy C
Does sound like the battery, if you have a multimeter check the terminal voltage.
If there is not even a click when you press the starter button it could be a loose batter lead - worth a look.
My OE battery lasted nearly 2 years untill it started flagging, I have since fitted a Lithium battery and it has been fine.
Posted: Tue Nov 23, 2021 5:57 pm
by Daiwiskers
Another vote for dead or dying battery
Posted: Tue Nov 23, 2021 6:13 pm
by philipw
Thanks very much for your advice.
I didn't think it would be the battery as the lights came on, however the multimeter says 9.9 volts, so it's on charge now.
I will let you know how this develops.
Thanks Philip.
Posted: Tue Nov 23, 2021 6:38 pm
by papasmurf
Thanks Philip.
9.9 volts you have a deceased battery.
Posted: Tue Nov 23, 2021 9:48 pm
by swiftjess
Absolutely! I doubt it will even charge being pancake - like 🙄
Posted: Tue Nov 23, 2021 10:49 pm
by Beezabryan
That battery is reminiscent of Monty Pythons parrot
Posted: Wed Nov 24, 2021 6:55 pm
by Andy C
Another vote for a dead parrot.....sorry battery.
Bin it and get a Lithium battery - about a 1/3rd of the weight but a bit more expensive.
