- Fri Nov 12, 2021 2:29 pm
#98910
Please note question is for a 1957 model Redditch which was originally 6 volts but now 12 for a number of years with no issues. Amp meter registered charging discharging previously. Today checking battery with multi meter for charging voltage so increased revs on bike and reading across battery terminals did not change from 12.6v - pre starting reading. Expecting it to rise as alternator produced output but as said stayed at 12.6v. Wondering then if rotor after 67 years can lose it magnetism. Bike uprated from 6v to 12v but has been standing for some time while sorted magneto (see earlier post this week) but battery seems to hold charge Alternatively could stator ring be no longer functioning effectively (or both stator and rotor failing). Note later British bikes with 12v had Zener Diodes fitted so not sure what parts I need given Lucas will have changed/developed their kit and as said bike now 12v not original 6v although assume as no problems previously the original alternator had plenty of capacity to run at 12v. I only have a simple rectifier. Not sure if this is right in terms of a useful test but if I remove/disconnect battery and read across the disconnected positive and negative wires get a reading of 1.5 volts when revving bike which seems to indicate there is alternator output and rectifier doing its job. Any comments helpful. regards Hugh
