- Tue Sep 25, 2012 6:45 pm
#1212
Your thoughts on this please gentlemen. A friend has a 2005 350 Bullet. Following a pump spindle failure and thence a bigend failure my friend had an extremely poor engine rebuild in Norfolk where he was visiting. He made it back to the Isle of Man. The bike has run for a few hundred miles since the rebuild, albeit leaking profusely. In the last couple of days the bike has taken to blowing scavenge side oil pump gaskets. A new gasket is lasting only minutes. Loosening the rocker banjos reveals an oil flow in the usual manner. There seems to be a build up of pressure as oil is squirting from the oil pump gasket. I was thinking maybe a blockage in the rocker blocks but would have expected, in that case, that there would be a high pressure squirt when the banjoes were loosened. He is using Morris 20/50. Any ideas are gratefully received.
