- Thu Aug 26, 2021 6:47 pm
#98161
Having some trouble with the Bullet 500 I just bought. Clutch problems I believe. Very hard to shift. Also there was no oil in the gearbox when I pulled the plug. There is no free play in the cable and no more adjustment. The adjustment at the gearbox makes no difference when adjusted. On the center stand in gear you can not turn the back wheel with the clutch in. Also I can see the side of the gearbox cover flex out slightly when you pull the clutch lever in. Wondering where to start.
