By guru
#98047
Has anyone used one of HM rear tyre hugger? (Short Pyramid) "Have you any feedback you can share Please", is noted its "Short" does it do the job, did you fit one now wished you got the other version that's for sale, did you have to modify yours or is it sound. Thanks Guys.
By Andy C
#98053
I fitted one to mine - not the short version.
Does what it says on the tin, keeps most of the crud off the shock absorber, and stops crud accumulating under teh rear mudguard.
By 410Rider
#99166
Cheap and cheerful, AND works - Old inner tube fastened / glued to short shock cover. Extends down to bottom of shock,
which after 5000 miles is still like new.
Himmi Inner Tube Hugger Sustitute.jpg (61.12 KiB) Viewed 893 times
By Andy C
#99190
Pic of the rear of my Him. before I washed it.
Full hugger fitted - to be honest it would be better if it extender further around the rear wheel, but it certainly does a good job of keeping the shock cleaner and stops crud accumulating under the rear of the bike.
