- Fri Aug 06, 2021 10:32 am
#97932
Any one know why my EV Himy head lamp has two bulbs fitted?, 1: main bulb is for dip / full bean 2: the smaller bulb that's located below the main light, which I thought would be as a daytime running light. Either my bike wired up wrong or Enfield has it wrong? When the ignition is turned on the lower bulb lights up (engine not started at this point), when the bike is started up both bulbs light up (main / lower bulb) with no option to switch to a daytime running light only. If the main bulb is working all the time what is the purpose of the smaller bulb as its not doing owt apart from supporting the mail light, If Enfield feel extra an light is required why not put a bigger bulb in there, I thought it may be as a parking light but take the key out (as you would when parking up) and everything is off. Is there a secret switch i don't know about ????
