piston ring gap
Posted: Thu Sep 20, 2012 5:21 pm
Hi, its being over 40 years since I did this,can any one remind me what the piston ring gap should be in the bore as I'm thinking that I may need to replace the rings. It has +20 pistons and the bores are perfect, The reason I would like to check is it is showing signs of compression passing the top ring. I'm hoping the previous owner assembled it wrong. For got to say its a 1960 Connie
Following my question about wiring a power box Thank you Norm and Les its now working as it should
