- Sat Jul 10, 2021 10:37 am
#97563
This is on my 2003 612 converted pre-unit bullet.
I have a crank mounted ignition which has rendered the whole distributor mechanism redundant. The casting has been removed and the opening blanked off.
When I first assembled it, I left out the two idler gears that normally run between the inlet cam and the distributor drive shaft on the premise that they were just unecessary mass.
Thing is, I get a low rev clattering noise under load. It goes away at higher revs and I'm not particularly in the habit of riding it about at low revs anyway. I'd initially suspected it was pinking but now I'm suspicious it could be cam balcklash. I'd pondered fitting adjustable cam spindles when I built the bike and decided against it on the basis that while the standard ones can't be adjusted tighter, neither can they come loose.
I'm now wondering if the mass of one or both of the idler pinnions might serve to have a damping effect on the cams?
I'm going to try Bullet Whisperers inlet cam retarding trick which should make it a bit softer at lower revs anyway? I was wondering if anyone has any thoughts about fitting one or both of the idler pinnions at the same time?
