- Sat Jun 19, 2021 10:17 am
#97220
For a while now when I switch the ignition on, the amber engine light will flash / flicker for quite some time, before staying on.
Sometimes the lamp comes on straight away with no flashing.
The pump does not prime untill the lamp stops flashing, but sometimes when the lamp comes on permanantly the pump will take ages to prime.
Sometimes the lamp will come straight on and the pump primes straight away.
Seems to me that it may be a dodgey connection, having said that I have removed / replaced the relay, and also taken the pump connector off and re fitted it.
Anyone any thoughts?
Bike seems to run perfectly OK once the pump is primed, the battery seems to be OK as lights are bright, and starter turns over OK, not checked it with a multimeter yet.
Previous bikes - far too many !!
