- Wed May 12, 2021 8:14 pm
#96725
From a previous post about broken brake shoes.
Note that the bolt holes in the cover plate for locating the rear brake cam bush are slotted,
to enable the brake shoe assy. to be centered in the drum. The brake cover plate assy with the
shoes should be fitted over the spindle into the brake drum and the brake applied as hard as
possible by means of the operating lever. This will centre the shoes in the drum. The brake
cover plate assembly should then be removed and the screws should then be tightened fully
and secured with the lock nuts. If the shoes are not correctly centred, the brake will be either
ineffective or too fierce. depending on whether the trailing or leading shoe first makes contact
with the drum. With the brake assy, correctly centered and screws securing the cam housing
correctly tightened wear on both linings should be approx equal."
Off Route, Recalculate?
