Well if it were a CDI bike, it would at least have a decent capacitor, hopefully.
However, if you read the original post he says its a ci Bullet, i.e. Cast Iron (cylinder), not CDI!
Could be both if it's a 2002 Indian home market 350 Electra, not that many of those over here.
windmill john wrote:
Mon May 03, 2021 6:23 am
Valve clearances too tight? That sounds like a possible cause. It would start cold, but no compression when hot; it could still run.
But the valve clearances open up when hot, unless this engine is different.
Adrian wrote:
Mon May 03, 2021 8:39 pm
As you were. :oops:
Flat battery? A nearly dead battery would allow you to start the bike but run into issues after riding for a bit then "recover" with some rest.
By windmill john
#96605
Wheaters wrote:
Mon May 03, 2021 8:58 pm
Exactly. Enough to keep running when running, but possibly too open (no compression) to start when stopped.
By Warren
#96610
Gentlemen, thankyou for the many replies. I’ve given all the easy things a really good going over and what I have noticed - what with all the engine turnovers - is that I seem to intermittently lose compression.
Time to pop the head I’d say and take a look-see.
She has 14k on the clock (400 with me) so a general clean-up is about due.
