- Sun May 02, 2021 8:50 pm
#96580
My 350 ci bullet (2000) has my heart broken.
She will start on the first, sometimes second, kick but God help you if she’s allowed to stall.
After a stall there is absolutely no way she’ll start again.
Dry, change plugs; check spark; check timing; clean points; check fuel; check battery power; check kill switch. You name it, it gets checked but it will not start.
I’ve tried the flooded-start routine - no good. I’ve tried the running bump start - no good.
Try next day and bingo! Off and away.
What am I missing?
All the standard things are spot-on. (Timing, plug and point gaps etc)
I have the standard mikcarb (new) with a trumpet air intake.
All ideas appreciated.
What am I missing?
