- Fri Mar 02, 2012 3:27 pm
#113
Hoping Paul M H Catches this thread. I decided to try an improve my TLS front brake in the light of your recent posting on the Brake Fade thread. Been fitting the HD cable but been having trouble routing it through the holes on the nacelle. My bike is a 2001 Classic 500. The cable WILL go through but because it's so much thicker than standard there doesn't seem to be enough distance between the nacelle hole and the brake lever. The 'S' turn needed seems too much.
Anyone come across the same problem? All suggestions thankfully REceived.
Tony R
Tony R
