- Fri Jan 15, 2021 7:20 am
#94855
Has anyone bled the rear brake on the Interceptor. I tried to bleed it from the master cylinder but no air came out and the brake pedal still goes to the 'floor' unless I pump it a few times. I think bleeding is different with ABS but I don't want to take it to the dealer if I can fix it myself. The brake works ok but should be better. The front one is perfect.
