Swinging Arm help
Posted: Sat Jan 09, 2021 6:34 pm
by 73a
I have fitted a bullet redditch swinging arm to a frame with thrust washers fitted to the inside of the frame , nice snug fit .
My concern is when the swinging arm spindle is tightened up the arm locks up tight is this correct , i have yet to fit the shocks.
the swinging arm was fitted up with the stay tool fitted between the shock absorber securing points.
your help would be appreciated , thanks ng
Re: Swinging Arm help
Posted: Sat Jan 09, 2021 8:14 pm
by Haggis
That is correct.
The tool holds the swingarm at the correct height while you tighten up the bolt.
This means the metalastic bushes are not under any load at normal swingarm height.
Once you have removed the tool the swingarm should be able to move up and down but under control of the metalastic bushes as the rubber twists.
Posted: Sat Jan 09, 2021 8:19 pm
by 73a
I dont metalasic bushes , i just a 9/16 spindle bolt and nuts , hence when a tighten the spindle nuts it tightens the thrust washers against the swinging arm and locks up tight, is this correct ?
Posted: Sun Jan 10, 2021 12:01 am
by Haggis
You have to have a bush or bearing of some kind so the swingarm can move up and down.
The meatalastic look solid from the outside.
Her is a picture of the bushes, also in the photo are white plastic bushes and spindle that are used on modern Enfield's.
Posted: Sun Jan 10, 2021 12:37 am
by stinkwheel
Aren't reddich bullet swingarms on bronze bushes?
Posted: Sun Jan 10, 2021 8:51 am
by 73a
Yes i have a have bronze bush swinging arm for my frame.
Posted: Sun Jan 10, 2021 11:20 am
by Haggis
If you have bronze bushes then you will also have a , chainstay bearing tube, as well as the long through bolt.
Part number 3.
https://www.hitchcocksmotorcycles.com/p ... pages/1104
Posted: Sun Jan 10, 2021 12:02 pm
by 73a
Yes as per picture , i have a chain stay and a 9/16 spindle , i have decided to build up the frame with the swinging arm stay loose and retighten when other items attached to see if the frame eases it shape.
Posted: Sun Jan 10, 2021 12:38 pm
by Haggis
Make sure the, chainstay bearing tube, is long enough.
There are different lengths.
When its fitted into the swingarm it should stick out a little at either end.?
Posted: Sun Jan 10, 2021 1:38 pm
by 73a
My bearing tube is flush with ends of swinging arm thrust faces, i persume the faces on swinging arm should run against face on thrust washers in the frame ?
